Is it possible to close BlockEdit with a command/script?
It would be great if there was a command or some Python API method to close Block Editor, effectively clicking this “OK” button:
Hi @Daniel_Krajnik,
No, there is not.
If you are scripting with Python, just modify the instance definition geometry directly.
– Dale
thanks, that’s good to know. I wanted to check if it’s possible to create a shortcut to exit from the interactive blockedit mode via a command. It wasn’t meant to be used in a “batch script”, but to ease frequent blockediting for the user if that makes sense.
