I’m curious if anyone has figured out a way to exit from the blockeditor while using a macro? I’m working on a drafting tool and I’d like to be able to run the operation with as little user input as possible. I see this functionality has been requested a few times over the years and wonder if it’s been implemented or if anyone has found a way to achieve this function on their own.
Bumping this for visibility. I see there’s been some work on this in the issue tracker under RH-34493 . I would find this command very helpful to my work flow
Disregard my message, I was trying to get the commands from the tracker to work without realizing they’re nested inside of -BlockEdit. Everything works great!
