Hi @fraguada ,
Firstly, thank you for the amazing Iris plugin. I tried exporting a rhino 7 model but I got this error as attached in the image. “File writing plugin has failed”. I am not sure why this is happening.
I followed the docs in this link - Iris Documentation
fraguada
(Luis Fraguada)
September 7, 2022, 9:25am
2
You will need to share the model for me to make any attempt to understand why exporting your file failed to export.
Hi @fraguada , I actually found out the reason. Looks like blocks are not supported by Iris. I have a few questions.
Is there any workaround apart from exploding the block?
Is there a way to get editable js code from Iris instead of min.js files?
When I’m orbiting the model in chrome, the model seems to randomly vanish. What should I do?
fraguada
(Luis Fraguada)
September 7, 2022, 10:04am
4
You should try your 3dm in the three.js editor: three.js editor . This is where we are focusing our web efforts. Here are some examples of how to build stuff with it: rhino-developer-samples/rhino3dm/js at 7 · mcneel/rhino-developer-samples · GitHub
