iRhino camera lens length?
What camera lens setting is default in iRhino?
Can iRhino use a 3dm’s lens and/or format settings stored in its SavedViews?
Thanks
Alan
The default is 50mm just like Rhino.
iRhino should use the custom lens length set by a saved view. Is that not the case for you?
Nope, I saved a view with a wide angle and another with a very long lens, and both come in looking the same.
Is there a way I can check what the came lens is while in iRhino?
irhino cam test.3dm (83.8 KB)
I see the difference clearly between named view 1.33 and 2.41
It matches what I see in desktop Rhino
Not at the moment. But I logged it as a feature request:
RV-1115 Camera lens length
Hm. Which version if iRhino are you using?
Latest Testflight version
Ah, the testflight WIP works as expected. Thanks. Don’t know why the other version of iRhino didn’t work.
But marking as Solution, thx.
Alan
