When creating a new file, there is a different settings for a lens length when compared to options.
Hello- one is the default, one is the actual number for a particular viewport - if you run SetView > World > Perspective, the number on the viewport should then match the default. Does that make sense withwhat you see?
I can see it now and it makes sense.
Wouldn’t it make more sense if deafult worked for all cases when new is implemented (new file in this case).
No big deal though but I always work with 35 mm lens ( even when I draw). This is my laziness speak.
