Are there any legal reasons why ironpython executables are not packaged with Rhino?
I doubt there are legal reasons, but @brian or @stevebaer would know better.
Can you tell me why you’d want the IronPython executables packaged with Rhino?
I think the answer to your question, however is “no”.
I am thinking of subprocessing ipy.exe from GH in order to reduce the load on that thread and use IronPython instead of Rhino for some calculations.
I have local installation of IronPython, but I don’t know what kind of issues this may cause to mix them up.
Now we’re definitely into @stevebaer’s territory
This shouldn’t cause any problems. Launching a separate process should work just fine.
Even if Rhino’s ironpython version is different from the one I have locally?
A separate process is a separate process. There shouldn’t be an issue, but I can’t guarantee it.
Ok then is it possible to add the ipy.exe(cutables) to be distributed along with Rhino? This will also answer another topic I created before:
We aren’t going to add this to the distribution (at least not for V6).
