Invisible imported geometries RhinoInsideRevit
Hi, I´m having some problems with the plugin. I am trying to create a general document in rhino. Editing the grid and the levels, but once I created the columns they are not visible. I notice no matter which component I used, any geometry was created. I try closing all the apps, and open again the document, creating new columns, and the component generates a warning that there´s the same elements on that position. I look the element by their IDs on revit, but any element was found. I already install the new version of rhino inside, but the problem was not solved.
This is typically either a Units or a or Phasing issue. (My guess would be phase)
