Rhino inside revit , element not found with element id
i’ve successfully created the elememts but it’s not shown in any views, already checked workset and visibility… i’ve just got this problem today.
already updated to 1.98326
Can you internalize the geometry and try in a new file? If that doesn’t reveal anything can you post the geometry? Thanks
Are you using Phase Filters? That affects visibility as well.
the project recently added phasing to the elements but the phase filter is set to show all though, i’ve tried in another revit file and it works, not sure is it about the revit files itself but supposingly the setting of both files are the same as they are linked to each other
