Introducing Cyclops: Real-Time Raytracing for Sustainable Design 🧩
Hi all! We are happy to announce that after years of development, Cyclops - a raytracing analysis tool by Foster + Partners - is now officially available to everyone. :globe_showing_europe_africa:
The development of Cyclops is driven by Foster + Partners’ commitment to sustainability. It is being released as a free plugin for Grasshopper to encourage widespread adoption and the integration of more sustainable design practices across the industry.
Realtime analysis
Cyclops speeds up raytracing based environmental analysis using NVIDIA GPUs, enabling real-time feedback for metrics such as radiation, sunlight hours, daylight and sky component.
Optimisation
Cyclops also offers a minimal update workflow using scenes where static data like geometries can be retained between analyses. This reduces computational overhead and together with the performance gains from running on the GPU, Cyclops becomes ideal for optimization workflows and iterative processes.
Scale
Cyclops is built to efficiently handle geometry and can run analysis on highly detailed models containing large amounts of data, such as those used in city-scale contexts. Since Cyclops primarily works with meshes, it efficiently processes dense and complex geometries while maintaining consistent analysis performance. Even with highly detailed models, the software ensures fast and reliable results without significant performance impact.
The plugin is developed by Foster + Partners’ Applied R+D Team, an integrated team of architects, engineers, data scientists and software developers. It is available for Rhino 7 & Rhino 8 via Package Manager/Food4Rhino with a 90 day update requirement (similar to Rhino WIP builds).
See below resources for more info:
Give it a go and let us know what you think!
For any related topics such as technical issues, bug reports, or feature requests, please use the cyclops tag and we’ll do our best to assist.
@WojciechKarnowka
I played around with this plugin a bit and I have to admit that it is indeed very fast and also pleasant to use. Could you write something more about the license?
From what I understand, it is free to use as long as you allow me. Could this plugin become paid in the future in the form of a subscription or a one-time fee? I assume your intentions are fair, but in the software world disappointments regarding changes in the way of licensing are common. It would be nice to clarify these doubts from the very beginning.
In any case, congratulations on a very cool tool and thanks for sharing!
Hi Jakub,
Glad to hear you’re enjoying Cyclops! All current features will always stay free and accessible.
The plugin runs on a 90-day renewable license to help catch bugs early and keep things stable while we’re still in early days. We release builds regularly — each new build also comes with its own 90-day validity. Rhino 8 users with auto-updates on will get them automatically. In Rhino 7 or with auto-updates off, just use the Package Manager to update manually. In the future, we may adjust the expiry period.
Let me know if anything’s unclear!
Best,
Wojciech
So, not Mac compatible. :slightly_frowning_face:
Hi ray,
Unfortunately no Mac support.
We rely heavily on a few Nvidia libraries as well as some Windows ones so Cyclops does require that you have an Nvidia GPU and run on Windows.
Hi all :sun:
We have recently released version 1.2.0 of Cyclops!
This version introduces the Sampling Setting object which consolidates the controls for the ray-tracing engine and exposes a few more parameters related to the Russian Roulette termination. The sampling settings includes a set of presets for ease of use. See below how the different parameters relate to parameters in the Radiance engine:
Cyclops Sampling Settings Radiance Parameter
Samples The square root of -ad
Max Bounces -ab
Roulette Threshold -lw
We also extended the feature set in relation to illuminance data and the creation of skies. Including multiple models both for luminous efficacy, luminance distribution and sky types when calculating daylight factors or sky components.
See changelog for more info.
Nice plugin! Do you have some comparative performance metrics against the ladybug tools?
Hi @crz_06,
We haven’t published anything. But you’re welcome to compare to radiance or any other software if you want. There are a few things to keep in mind:
  • Cyclops does not include any default ground reflectance so modelling a ground plane and context geometry is important. Edit: Cyclops does now include ground reflectance, following the release of version 1.3.
  • There is no illuminance interpolation like in radiance, just pure Monte Carlo raytracing. So if you want to run like for like the -aa parameter in radiance needs to be set to 0.
  • Both direct and diffuse contribution is evaluated using the patches in the sky in Cyclops. Meaning that for analyses where exact shadows from the sun is important you might see a difference.
  • The time pattern in Cyclops samples time within the hour, rather than at the hour mark. This might differ from other apps depending on what you’re doing.
I’m using cyclops for fast daylight factor and daylight autonomy simulations of an office building. But the results for the whole floor are the same despite i have windows on only one side. Is this a bug or do I something wrong?
Thanks! Wouter
Hi @Wouter_Notenbomer , could you please post in a New Topic, tag ‘Cyclops’, share a screenshot and ideally a file? Thank you!
The F+P portfolio certainly doesn’t suggest a “commitment to sustainability”
Hi, I am getting an error that cant load CUDA library. I have been using the plugin before so not such which dependency broke. is there something in the special folders I can check to re stablish the connection to the CUDA library?
Hi @Roncal_Andres,
Could you please post a new topic, tag ‘Cyclops’ and share Nvidia driver version and GPU name and we’ll help you out!
