Trying to trim a cylinder with this saddle shape with circular arc cross sections. Trim
, Split
, Intersect
all fail.
Saddle Trim.3dm (128.8 KB)
, Split
, Intersect
all fail.
Try to split the cylinder where it has coincident edges with the red surface and then do the intersection
I already have the bottom half split from the two top pieces.
the corners of the red surface are degenerated.
the edges form a 180-degree “corner.” (which is not a corner)
many calculations / operations will fail because of this. - the normal does not exist at the degenerated corner.
EDIT:
To proof: just trim (_split Isocurve shrink=yes) a very small portion near the degenerated edge - and you can intersect and trim - but of course not build the final joined surface)
