Did interpcrv lose its StartTangent option? It seems like interpcrv lost its StartTangent option.
Eric
Eric
Hi Eric… Yikes, it seems to have lost both tangent options… I’ll see if I can find out if this is by design for some reason - thanks.
@ejolley - sorry - I had mine set to degree 5 - you may have as well - it only offers the options on degree 3 curves.
Hi Pascal,
Set to Deg 3 here; still no tangent options.
e
Ah - set SubDFriendly to No.
That’s it!
Thanks
I am not wild about disappearing UI… but I am not sure what the alternative is - leave it there but print a message if it cannot be used?
RH-67010 InterpCrv: experiment with persistent command line options
No grayed-out options on the command line I suppose…
Right- that’s another way and I do not know if that is a thing…
