Instance block to brep or mesh
how can I convert this block into brep or mesh? i do eplodeblock but my laptop crashes and i use explode and I get block, surface and meshes
tree.3dm (2.3 MB)
thanks in advance
Hi Albert - I’d use Explode to get down to just the meshes. Use SelColor to select (thousands) meshes of the same color and Join. In the end you should have 6 disjoint meshes. It makes a very large file, for one tree…
thanks a lot.
it says to me when I use selcolor no object added to selection
could you please send me what you get?
because what i need it is transfor the block which contains braches and leaves into meshes
i had already the meshes in one layer and connected to a mesh com`ponent
Hi Albert:
ExplodeBlock
Then, Select one mesh object from the result > SelColor > Join. Hide the result. Repeat with another mesh object.
thanks a lot for your patient. done. but how can I convert that block instances into brep or meshes to use in energy simulations?
Hi Albert - I am not sure I follow. The block contains thousands of meshes - ExplodeBlock will return all of those meshes. The SelColor and Join is simply to reduce the number of meshes.
if i create a mesh and I select “set multiple meshes” and I select the block instances I cannot get in the component
Hi Albert - if you are working in Grashopper, please post the question on the GH forum.
ok sorry thanks a lot
