Installing GH2 from server: https://yak.rhino3d.com/versions/grasshopper2
Is it possible to build the .rhp from files on the server
For example can we use Yak to install the Gh2 package from above url on an offline machine?
Hi Arkadius -
Since there’s always a machine that’s online, the easiest way would be to install packages through Rhino on that machine. You can then find the downloaded files in the following folder and can copy these to a machine that is offline.
%AppData%\McNeel\Rhinoceros\packages
If you don’t have Rhino on the online machine, you’ll still need yak.exe and can then run that as a command line tool: Rhino - What is the Package Manager?
Him @wim,
Thanks alot.
