Inserting block in worksession bug
Hi, I have problems inserting blocks into worksessions.
I have these files:
worksession.rws
file1.3dm
file2.3dm
block.3dm
Worksession opens file1 for edit and file2 attached as reference. There is a block inserted in file2.
I want to open the worksession and insert the block into file1.
I use Insert file - Block definition - linked, Layer state - reference.
The block doesnt insert correctly. It behaves like it was somehow inserted into the attached file. I can see the block, but i cannot move it or delete it. There are of course no changes made to file2.
If I open file1, insert block, save it, open worksessioin, everything is ok, the block is inserted as it should. But i need to insert in when the worksession is active.
Is there something im doing wrong?
Thanks!
Hello - I see this - thanks, I don’t think you are doing anything wrong - at the moment it looks like a bug to me.
https://mcneel.myjetbrains.com/youtrack/issue/RH-52824
