Inserted image not loading again when reopen the file
Hello to all!
I am testing the latest Rhino version (Rhino 7), and I can see there is an issue when reloading the Rhino file with an attached / inserted image. The image is not loading. I just can see a gray box instead. I can fix it manually by checking the path in object properties and point to the correct image. But this is time consuming procedure. (PS. I did not change the path of the image, or the file position in my folders. Nothing is changed)
Best regards,
Djordje.
Please paste the result of the Rhino command _SystemInfo.
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Evaluation, build 2020-12-08
License details: Cloud Zoo
Expires on: 2021-03-09
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Radeon RX Vega (AMD) Memory: 8GB, Driver date: 5-25-2020 (M-D-Y). OpenGL Ver: 4.6.13596 Compatibility Profile Context 20.5.1 27.20.1017.1011
> Accelerated graphics device with 8 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 5-25-2020
Driver Version: 27.20.1017.1011
Z-Buffer depth: 24 bits
Total Video Memory: 8176 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
Can you attach a file with which this happens? I have a hard time reproducing this.
Hmm, maybe you intended to write this in your other topic? :slight_smile: (Right click changed behavior in Rhino 7)
OOPS! I opened like 7 topics. Sorry. I will correct everything.
I will attach a file as soon it happens again. I have limited time at the moment. But in next days at work, I will upload something for sure.
Best regards,
Djordje.
