Inserted block 1000 times larger than expected
Hi Jeremy,
I see what you mean and you’re probably right.
However, what is strange is that if you import the file it comes in the correct size. It seems that import ignores units altogether, which is unexpected to me, but maybe as designed… (1)
To continue your example after inserting the block in the layout
  1. import the block that you exported. it will have 10mm radius
  2. in model canvas, insert the block and it will have 10 m radius
  3. in model canvas, import the block and it will have 10 m radius
About your workaround, I think that was indeed why I have not noticed before. I did originally made the blocks in model and did not change them for a while. I started noticing the issue after editing them in place on Layouts and exporting them. Even then, I would mostly export the several layout blocks at the same time to a temporary file and import (instead of inserting) into the new layout.
N
(1) … come to think of it that could explain why sometimes I had problems with importing third party files. I was probably using my shortcut which uses Import and not Insert.
see Consider scaling in importing - Rhino / Rhino for Windows - McNeel Forum
