Inquiry for issue in analyzing tensegrity structure
Dear karamba3D team,
Because tensegrity structure is kinetic structure, there are issues happening on analyze component. I follow advices on Karamba3D manual.
  1. I check the support points are not same points as Hinge points.
  2. I activate the bend stiffness of cables. Then, the analyze component works normally. (But in generally, cables in tensegrity only contain tensile strength, so it should not be bend?)
    (file is attached in the buttom)
As a result, is this a right way to analyze tensegrity structure?
Thank you for reading this issue.
Best regard,
Ping
241227tensegrity structure issue.gh (73.5 KB)
Hi, you just need to increase the pretension so that you can achieve fully tension elements in the cables. When i open the script everything seems to work however.
