Hey,
I am trying to analyse the forces acting in a tensegrity structure, and cant quiet seem to get it to work.
It is a system of struts and cables that is self supporting, and I am wanting to look at the internal forces when it is under compression.
I have modeled all the struts and cables so that the cables are essentially struts with buckling and bending turned off, and the struts have no bending stiffness as well.
There are two main issues im having:
1 - When I fix one base support and have another semi fixed, the structure does not deflect correctly, and analysis doesnt have a converging displacement.
2 - When I remove the semi fixed support, the structure displaces correctly , but still doesnt have a converging displacement.
What makes this weirder is that when I incrementally increase the load, it seems to be deflecting correctly, but at no point does the analysis converge.
Can somebody please help?
Thanks!
James
Tensegrity_Anlaysis_Model.gh (44.9 KB)
