InjectAttr Error
Issue with InjectAttr ShapeDiver Inject Attribute Component :
Rhino 7SR26 + SD Plugin 1.16
Same issue with officiel GH exemple file:
I’ve tried to uninstall SD plugin, restart Rhino, reinstall SD plugin without better results.
Could you share one of the files causing the issue?
attr-test-file.gh (17.3 KB)
:pray:
Current status: no one in our team can reproduce these issues. We suspect it is caused by a dll conflict with another installed plugin. If you can share with me (here or in PM) the list of Grasshopper plugins you have installed on your machine, that would help us identify the issue (I know, it’s a little cumbersome, you can send a screenshot of both your Package folder and your Components folder).
You could also try to uninstall plugins on your side and check if you can find which other plugin causes the conflict.
Working now after some cleaning in my GH Component/Libraries. :tada: Thanks !
Do you mean that both issues (this one and the other topic you created) were solved by cleaning your libraries? By cleaning, do you mean that you uninstalled some of them completely or just updated them to the latest versions? It would be great if we could pinpoint exactly which plugin was causing the issue!
