Inflation/compression of a tissue model
Hello everyone,
I am currently working on a parametric model of a kidney and I am trying to simulate a simplified deflation process in Grasshopper.
The goal is to create a model that can transition from an inflated state (based on a CT-derived geometry) towards a compressed/deflated state.. My initial assumption was that this could be approached by creating a central skeleton of anchored points and connecting the outer surface to this skeleton using a network of springs or length constraints. The idea was that shortening these constraints would allow the outer surface to smoothly collapse towards the internal structure.
However, I am struggling to achieve a stable and realistic deformation. The current approach tends to create local distortions, mesh explosions, or unnatural folding rather than a smooth global compression of the kidney shape.
The model is a relatively clean remeshed surface, and I have access to the internal branching structure from the CT data, which I thought could potentially be useful as an internal constraint network.
Any suggestions, examples, or references would be greatly appreciated.
Thank you!
Deflating_0.02.gh (24.1 KB)
Deflate_0.02.3dm (234.3 KB)
The .3dm file appears to be empty but the Rhino command ‘show’ fixes that.
Indeed, I’ve used the weaverbird plugin and must have forgotten some things in the export of the file. Hope this version fixes it!
Deflate_0.04.3dm (210.1 KB)
Hey Ruben, I couldn’t get an interesting result using negative pressure strength values. I’m not sure that actually works. Instead, I suggest using a vector to move the mesh vertices toward the ‘central skeleton’. It worked pretty well, except at one junction, where I had to add a small extra line segment to force the shrinking in the right direction.
kidney_gh
