Hi.
I am working to obtain the appropriate length of a piece before bending with the squish command. Before using squish I measure the radius in the corner of the surface and the value appears in the window, after squishing the surface those radius become infinite so the cutting machine is unable to read it. Someone know how to correct that?
Not without a file or some code to look at. Did you post this in the Grasshopper Developer category on purpose, i.e. are you looking to get help with C#, VB or Python?
Yes, I am looking for help with python. The idea is to take different bending shapes and obtain the geometry flat in order to cut it with the appropriate perimeter. I was trying to do it manually in rhino once the curves are generated but the process is too long.
Thanks for the help
