Hi, I haven’t worked in Rhino for two years and am now relearning it … I seem to remember that there was some way (a plug-in? a setting?) to modify the little view-indicator in the top left corner of the work space while paning in perspective view so that it indicates always the view you’re closest to. So if (in perspective) I see my object from the front, it says “front” in the black field in the upper left corner. If I then slowly pan towards the right view, it changes to “right” at a certain point.
Do I remember this right, or is it a case of wishful thinking??
Thanks in advance for any clue - Jan
Bingo, that is it! Thanks a lot! Good to know I remembered rightly …
