I’m having trouble rendering this file - it is as if there is a clipping plane all the time, however, there is no clipping plane after showing all objects and layers, and in the viewport, the objects are whole. When I change views, same things happen. The box that is covered is below the 0 in the z axis. The plane you see is the bottom of a box that extends above 0 in the z-axis.
Does anyone know how to fix this issue?
Thank you.
