Hello - there is one curve in there which has a self-intersection preventing PlanarSrf from working - if you clean that up, PlanarSrf should be what you need, I guess.
Hello - just boring old ‘binary’ testing - it looked wrong and I get the error message with all the curves, so try half at a time and half of those - it’s pretty fast to work down to a manageable few curves.
Thanks a lot, the PlanarSrf worked well. Now I have a surface. For #2 question, what’s your suggestion? any possibility of hiding these seam lines during array? Thanks
I see, thanks! Does it also implies that the common/recommended process in grasshopper is to first establish curves (then array or scale or move…whatever) then finally the surface creation is the last/ among the last in procedure? Thanks!
