Importing obj from blender into Rhino and simpiflying the derived subd
Hi, i have an obj imported from blender that has many meshes which can be converted into subd, but the resulting subd is almost impossible to modify because there are so many faces. What is a clever way to simplify the subd to get the main control loops/edges as the red line below? thanks much!
Extract the red curves and use those as guides for QuadRemesh
Thanks, Martin. Will try that!
If it doesn’t work out, post a Rhino file with your objects. Should the file be too large, try the save small option in Rhino.
