Import layout oddity
If I import a layout which has a detail that is being clipped with a clipping plane, the imported layout / detail will be clipped as well (cool), but the clipping plane that goes with that detail does not come along, so you now have a detail in which you can’t modify the clipping plane (not so cool).
I think the way I would like to see this handled would be when importing the layout, you get a little message box asking if you want to import clipping planes which are affecting details that are about to be imported. If the user says no, then don’t clip the detail. Otherwise maintain the detail clipping but bring the clipping plane that is doing it along for the ride.
Thanks,
Sam
Hi Sam - thanks, I’ll test and get this on the pile.
http://mcneel.myjetbrains.com/youtrack/issue/RH-32010
Ran into this same issue today! Can’t disable the phantom clipping plane in the imported layout, and I need to move it, so I’ll need to redo the whole layout.
RH-32010 is fixed in Rhino 8 Service Release 36
