It used to work slow but without problems, something is broken for about week or so.
I have a folder with 700+ files from which i have to read the data stored on the specific layer.
While Human is doing this fast and with 100% success rate (less than 20 sec. for +700 files), Rhino is failing in almost every case.
First attempt - loading 10 items / passed 9
This urgently calls for attention. If you keep saying It works for us, I’d be happy to prove you it is not. If you can’t find resonable setup with hundreds of files I can test any update here.
Besides, how this one is supposed to work? I have tried any kind of layer naming and it is not working, therefore it takes ages to do any more-volumetric test:
I know the drill, not sure how this could be relevant.
I missed the moment when the change happened. One suspicion: I had this issue in V7 with older component and recently in V8.
I only realised I have installed VisualARQ for V8 recently, V7 have it installed as well.
All recent updates.
sysinfo:
Rhino 8 SR19 2025-4-22 (Rhino 8, 8.19.25112.13001, Git hash:master @ 0fe5f551e3e34ca51834ba0ca2217647d8027942)
License type: Commercial, build 2025-04-22
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary display and OpenGL: Radeon Pro 560X (AMD) Memory: 4GB, Driver date: 11-7-2024 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.30.45.21 30.0.13045.21001
> Integrated accelerated graphics device with 6 adapter port(s)
Primary OpenGL: Radeon Pro 560X (AMD) Memory: 4GB, Driver date: 11-7-2024 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.30.45.21 30.0.13045.21001
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 11-7-2024
Driver Version: 30.0.13045.21001
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Cyberstrak\R8\CS_ModelingPlugIn.rhp “Cyberstrak Modeling PlugIn”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\Piotr\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Garage\8.7.24140\net7.0\Garage.rhp “Garage” 8.7.24140.15431
I think I am close to solving the case.
I put this into work in WiP where I don’t have VisualARQ installed and the time was 20% of initial computation and 100% success rate:
Each file in the library is a model with bounding box on a separate layer.
Bounding box has some attributes assigned which I am trying to read upon loading.
I am only interested in loading boxes as they are the fastest to load.
