Image Edge detection
Hi, I need to detect edges of shapes in the pictures in grasshopper. Although I used the Firefly plug-in for that, it did not work properly, and the quality is not so good. Is anyone able to help me with this issue?
Have you tried Vectorize?
You can download it from the package manager.
This is done in Grasshopper:
سلام وقت شما بخیر، همچین چیزی مدنظرتونه؟
شاید پلاگین جاوید هم بتونه کمکتون کنه از دکتر اسماعیل بیگی بپرسید.
@Mahdiyar
Hi Martin, I just tried installing the latest version from Package Manager, but I can’t seem to find the Grasshopper component, nor do I see any .gha files named Vectorize. How did you get it working?
It should be in your roaming appdata:
"...\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Vectorize\8.4.24044\VectorizeGh.gha"
and appear in a gh canvas search:
And in the Curve|Util toolbar.
I’m pretty sure I installed it through package manager
Hmmm, maybe the version that ships with the Grasshopper component isn’t available for Rhino 7. This is the latest version that’s available via my Package Manager:
And I’m not finding any VectorizeGh file on my system:
Maybe @dale knows?
That appears to be the case, here’s the latest Rhino 8 version:
As you were :see_no_evil:
Yes, looking at Dale’s github repositories, the release with grasshopper support is R8 only. There’s an old repository for R7 and that does not include any grasshopper support.
That,s great! Yes, I am looking for something like the one you sent.
Thank you so much!
