Could anyone give me an example what these components are used for?
Thanks in advance.
Thanks in advance.
Thet don’t look like vanilla GH components though…
I thought so too. This got installed when I was installing everything from _TestPackageManager
@jesterking (@nathanletwory) are these yours?
I noticed also the icons of Raytraced plugin for GH are updated.
They’re mine, but I think you can only get them via the PackageManager.
They are used to create images. You set up some edges (for drawing curves) and fills (for filling regions), then send some shapes with these edges and fills to a Draw Image component.
They are not mine. GhShaderNodes is my GH component.
@nathanletwory,
My bad then, since I saw it’s saving to image files I assumed it’s an extension of GhShaderNodes just placed in another tab.
When I tried to save an image having a rectangle in it it could not be previewed with Picasa so I wanted to ask if there are any tutorials in using these?
But since it’s for components I assume it is more complicated than that.
What image format did you export as? PNG is typically the most reliable.
Yes, PNG.
Now I decided to open it with paint.net and it wasn’t empty just really really small
To be exact it was 1 pixel
