Hi guys
I would like to know if there is any way to ignore the geometry without doing booleans (as there is in Vray or other renders). Only with a material o parameter on the material.
Regards and thanks ![]()
Hi guys
Do you mean ray visibility of geometry? For instance render only when hit by camera rays, but ignore otherwise?
Yes, it would be great if I could instantiate the geometry of the diamond and ignore the metal. So the diamond refraction will always have the same result, regardless if there is metal inside of the gem.
Thanks
There is currently no way for users to set that, but the engine itself is capable of that.
Thanks, nathan. It will be good to see it in the future
I think for jewelers this is a very important setting for rendering.
It reduces the working time.
gemvision (matrix gold) has only recently been able to make this kind of gems setting for the Rhino renderer.
