Hi together,
the basic idea is: having a boolean. When it is set to true a geometry is enabled. When it is set to false the geometry is disabled?
How can this be done? Thanks in advance!
Hi together,
Do you mean enable/disable the visibility or the Rhino geometry? If so, there is some discussion on some approaches here that might help. There is a ghpython example as well as a plugin by @Michael_Pryor called blindfold.
thanks @chanley for your sugestion however I still want to process the geometry.
I need something to deactivate the group with the geometry and send meshes if false and it should be actived if true.
ah, I see…I think. This sounds like a job for metahopper. There is a component called “group toggle”. If you add it to the group, and when you toggle it on or off, it disables the components in the group. There are probably a few other ways, using metahopper, to add some other type of “enable/disable” logic.
@andheum might be able to provide some more tips.
