IdeaStatica - deconstruct welds - component v0.2.1 - bug
Hello Nathan
I have a node created in IdeaStatica v23. When I have installed the component package in grasshopper in version 0.1.16, I noticed that all welds are correctly deconstructed, i.e. 29 quantities. When I installed the latest package in version 0.2.1 and opened the same node, the welds are no longer correctly deconstructed and their number is smaller (24 quantities). I think this is a bug in the latest version of IdeaStatica components in grasshopper and is related to the fact that welds in IdeaStatica can be created manually and then everything is ok or use an automaton (e.g. for welding ribs - and then the latest component does not recognize 3 edges, only one).
Just tagging @nathanluke5 , not sure if he checking this otherwise.
Also, do we need a sub-category dedicated for IdeaStatica?
Hi Oskar -
fwiw, that’s only a link to the user’s profile. [And from that profile page, you can see that Nathan last checked in on May 16th]
You can hail a user with @ → @nathanluke5
Cheers Wim, but I also sent him a private message on Teams since I know Nathan.
He also might have email notifications on when getting tagged, similar to what I have.
Hej Oskar -
The only point I was trying to make is that adding a link to a user profile is not tagging.
Cheers,
Oh, my bad I missed the @ my bad! Thanks!
Hi Oskar
Maybe your suggestion to start a new sub-category dedicated for IdeaStatica is actually a good idea.
Hi @BIM_Tekla, we are looking into this and will get back to you soon. I am on holidays for a couple of weeks but will ask someone else to take a look.
Hi Stefano
Please find enclosed IdeaStatica node.
AP-090.zip (73.2 KB)
Thanks Chris,
We have found the issue and will fix it
Hi @BIM_Tekla , the fix is implemented in the latest patch 25.0.2.1757
Please let me know if the issue persist
Hi Stefano
Thank You for information, but where I can download this fix?
Hi Chris, you can get it from this link
Hi Stefano
Thank You very much for your help. Now it`s working.
