Grasshopper is akin to a programming language, requiring an understanding of syntax, components, structure, etc. Like when learning a programming language, its best to work your way up in terms of complexity with smaller projects before you tackle something large.
If you are completely unfamiliar with Grasshopper, I would start here: https://www.grasshopper3d.com/page/tutorials-1
Specifically with the videos by David Rutten. They do a great job introducing the basics.
If you finish the videos or are a bit more advanced, I would recommend trying to model something simple in Rhino first, then recreating it in Grasshopper as a parametric model while challenging yourself (how would I place these along a curve, how would I intersect these two sets of solids, how do I isolate items that are too large or too small). I would also try to learn the basic data types of Grasshopper, the AAD_Algorithms books are a good start.
Keep doing this until you can determine when Grasshopper would be the correct tool to use for a given project, because none of these projects used Grasshopper alone (or maybe at all). This is important, because once you can determine when Grasshopper would be useful in a given workflow, you can start rationalizing designs or installing plugins to expand Grasshopper’s utility.
To demonstrate this, I’m not sure what your site conditions are, the goals of the project, or the constraints of the design, and Grasshopper will never be able to tell me this. However I see some bridges and support diagrams with greenery, so if tasked with creating computational designs in Grasshopper, I would think to use the plugins Kangaroo with Karamba to simulate tensile systems and Ladybug to simulate sunlight exposure. The geometry could be anything (paneling, SubD, steel struts), and thus might be solvable with base Grasshopper - the key takeaway is that you need to determine when to use which tools, and that will require practice.
