I dont know how to model the outer shell of the dance palace by UNS
i did this using curves and loft the main part of the shell looks fine but the entrance has that kind of curve that i cant get out of loft tool, so any reccomendation on how to go about this model, how i can create it. thanks
Try using Sweep2 with section curves.
the problem is that part is not all curved some places are flat while other are curved and the curve section changes a lot so that wouldn’t work.
@Diar_Pishtivan Have yuo actually tried using Sweep2, or are you assuming it will not work? You can use as many curved sections in Sweep2 as needed, and the sections can be a mixture of flat and differing amounts of curvature.
i just assumed it was one section per sweep and not multiple section wait let me try
@davidcockey thank you so much man it turned out pretty good
