Hi everyone!
I used grasshopper to realize “a curve from two views”, as you see, the two red lines are two views (perpendicular to each other), and the blue line is the created one, and it is seperated. I am quite confused why this happened.
Is there anyway I can get a continous curve, or the original curves have some problem?
Thanks for any help!
So cool, Seghier!
That’s my idea: I want to create a centerline of a irregular pipe. I project the pipe to two views, and create the 2D centerlines of the two views, then try to create the 3D centerline from the two views.
It seems the 2D centerlines have problems.
By the way, how do you build the line you show?
Thanks again!
