After sliding the slider in Grasshopper, this prompt appeared in the operation window, and then I couldn’t operate it anymore. What’s going on?
Hi -
You haven’t provided enough information for anyone to know.
From that screenshot, it looks like you ran the Curve
command in Rhino. How is that related to the slider in Grasshopper?
Since you used your phone to take a screenshot and not the Windows Print Screen function, does that mean that your entire PC became unresponsive?
Please start by running the Rhino SystemInfo
command and copy-paste the result here.
It might be that I slid the slider, causing the generated object to be too large and exceed the screen. How should I fix this?
It might be that I’ve moved the slider too much, causing the generated object to exceed the screen size. How can I fix this?
