hello,
In Transform almost all functions are lost ( move , rotate …)
Did I do something wrong ?
hi @robbertwescher can you run _SystemInfo in Rhino and post back the results?
Good Morning Gijs ( are you Dutch? )
Rhino didn’t start up at all this morning , so I made a fresh installation , no changes in Grasshopper though.
Rhino 8 SR10 2024-8-13 (Rhino 8, 8.10.24226.13001, Git hash:master @ c36ab43d576d4854b29b091b6b3a38e09decabf5)
License type: Commercial, build 2024-08-13
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 965M (NVidia) Memory: 2GB, Driver date: 7-2-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.96
Accelerated graphics device with 4 adapter port(s)
Windows Main Display attached to adapter port #0
Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-2-2021
Driver Version: 27.21.14.6296
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.10.24226.13001
C:\Users\Robbert\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.10.24226.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.10.24226.13001
note that your graphics card has lower specs than the recommended minimum to run Rhino 8, and a very old display driver. That doesn’t explain the missing transform tools though.
I would try to run a Rhino repair to see if that makes a difference:
Good Morning Gijs,
I already made a Clean installation of RH8 , same grasshopper , what more can I do ?
By the way , transform is still there in my old RH 7 , but i get this message by starting it up.
Hello Gijs,
Rhino 8 didn’t start up this morning again , obvious the problem is bigger then just the grasshopper issue.
New installation works for a day , next day , same problem .
RH 7 runs fine.
Can it be a lisence issue ?
Greetings Robbert
Morning Gijs,
new Issue ,
De-installed RH8 , deleted the maps in program files , installed RH8 new , works fine ( but it still remembers my last opened /saved files ??? ) grasshopper issue the same.
Rhino asks to install an update , after closing RH8 and updating ist doesn’t start up anymore……
Hope you’ve got a solution form me soon.
Greetings Robbert
Try running using safemode.
Tested safe mode , RH8 doesn’t start up , same issue.
Greetings Robbert
what if you go to task manager? do you see a process called Rhino.exe?
hello,
Until yet i replied to teh E-Mails you sent , when I take a look at the issue at your portal I saw that Gijs asked to REPAIR Rhino 8.
After running repair RH8 started up und Transform in Grasshopper is back.
Thanks for the support.
