Did you create some?
Are you using wireframe mode?
Hello - two things to check -
- Make sure the display mode is set to show curves (Display panel)
- In Options > View > Open GL page, un-check the ‘GPU Tessellation’ setting.
It may be that you could use a video driver update as well.
thank you! 2nd one was worked!! ^^
