HALO ~I can’t change units of karamba in GH。
I don’t know what caused it.I look forward to your help.
Thinks very much ~
Hi, this only changes the units of your model geometry, not the cross sections.
Hi~If I want to change the cross-sectional unit, how should I do it?
Hi, it is not possible to do so
Hello, does the current version of Karamba not have the function to change the section units? I remember that previous versions allowed for changing section units. In the last version, I changed all the section input units to mm.
I have already customized the settings in the document as shown in the image, but I still cannot change the section input units.
Hello, can you help me with this problem? I would be very grateful!
Hello @AaronYeYe,
settings “CustomUnits” in the “karamba.ini”-file sets the input units as expected (using Karamba3D 3.1.4):
It does not change however the tool-tip entries in components that have been already placed on the canvas. Making the input-units more flexible and safe to change is on our TODO-list.
– Clemens
