I Can only print A3 PDF´s
When I “Export selected”, choose pdf, A1, portrait and for example 1:100. It shows perfectly in the preview window what will be on it.
But when I then open the pdf. Its only A3. Stille 1:100 but only a part of the preview window is there.
I tried to reinstall Rhino. But it stille happens. And it has worked before. I really hope that someone has a quick solution for it :slight_smile:
Does this still happen if you use Print instead of Export?
Hi Sorena
First draw a rectangle in the size (example for A3: 297*420mm) you want around of your objects;
Then check out print option (ctrl+P), set it to rhino PDF, fix size then in view and output scale window click on Window and choose your own rectangle.
Cheers
Alireza
Yes it Does . Its very Strange . Like I accidently clicked somewhere for prints only to be A3
Thanks.
I do that.
But The problem is that I Cant do it with A0, A1 and A2 anymore
Hej Søren -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR35 2023-12-12 (Rhino 7, 7.35.23346.11001, Git hash:master @ 6916542aa86609e2c43094fedcff51a3bd3c5723)
License type: Educational, build 2023-12-12
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: NVIDIA Quadro T1000 (NVidia) Memory: 4GB, Driver date: 7-6-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.69
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-6-2022
Driver Version: 31.0.15.1669
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\sa\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.23275.1101
C:\Users\sa\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2019.11.5.949\Lumion\Rhino 6.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\Geometry Gym\Rhino7\BullAnt.rhp “bullant” 1.5.6.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.35.23346.11001
C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp “BlockEdit” 7.35.23346.11001
C:\Users\sa\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
