Hello everybody
I am beginner with the Human UI and I am trying to make a really simple app.
I wanted to create a panel with the interactive sliders. I want them to appear one after another.
If one slider is being used (its parameter is higher than a certain value - in this case more than 4.5) another one is appearing below. If I repeat this process on the new slider another one is appearing below and so on.
Everything in GH window is working properly but in the Human UI window -
the slider seems locked. The movement is limited to 0.1 then reset to default value.
I tried to add “set slider” but the result was the same, perhaps I made it in the improper way.
I guess I made some simple mistake, could someone please help me with that? I am attaching photos and the GH file below.
Thanks
GH file
sliders problem.gh (11.8 KB)
slider locked
slight change for a moment and reset
When I use sliders directly from GH everything is working properly
When I put values manually everything is working properly
