This is probably one of those mystery problems that cannot be answered in a forum but maybe it will generate some suggestions.
I have a file containing a part that was about 30MB.
I did some editing to the part then saved. The file is now about 600MB.
What might cause such extreme growth?
The reason I was editing was that I had hoped to make things smaller to create an example for a question I had asked earlier.
That sounds quite strange, though…
I might still check to make sure record history is off.
Using another filename, you might try saving the file with the save small setting checked. Using complicated mesh settings might affect file size. If you mesh a single 1 meter sphere with .001mm maximum edge length, I should think the file size would likely be large.
If all else fails, you can create a file a file with duplicate units, and then copy and paste everything in there.
It looks like record history is OFF. However, when I try to copy and paste to a fresh file, I get the message
“Unable to paste, no Rhino objects or text on the clipboard.”
wim
(Wim Dekeyser)
May 6, 2016, 8:18pm
4
But what about the SaveSmall suggestion? How big is the file after that?
It’s pretty geeky, but the Audit3dmFile command is my go-to tool for this sort of thing.
Usually, the file is packed full of plug-in data or maybe inappropriately large bitmap files.
No change at all with save small.
SaveSmall strips out render meshes, but not plug-ins data or embedded bitmaps.
Testing 3dm Archive: /Users//Documents/Rhino/Parts/Pylon V02 014.3dm
Start Section: Id bytes (offset Id to Id)
Offset: 0
3dm archive version: 50
Interface Name: Rhinoceros 5.0 - English Commercial, build 0000-00-00 - (compiled Oct 12 2015)
SDK Version: 201103025.201412015
OpenNURBS Version: 201412015
3dm Version: 5
Operating System: Apple Intel 64-bit Platform OS X Version 10.10.5 (Build 14F1713)
3DM I/O processor: OpenNURBS toolkit version 201412015 (compiled on Oct 12 2015)
Properties Section: 3411 bytes (offset 375 to 3786)
3dm archive openNURBS version: 201412015
Application Information:
Name: "Mac Rhinoceros 5.0"
URL: "http://www.rhino3d.com "
Details: "English Commercial, build 0000-00-00"
Revision History:
Create Time: Sunday September 20 16:09:42 2015 UCT
Last Edit Time: Friday May 06 20:03:34 2016 UCT
Revision Count: 146
Created By: ""
Last Edit By: ""
Settings Section: 24469 bytes (offset 3786 to 28255)
Plug-ins:
Name: 3D Studio Export
Version: Oct 12 2015 03:29:46
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_3DS.rhp
SDK Version: C++ -1.-1
Name: 3D Studio Import
Version: Oct 12 2015 03:29:41
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_3DS.rhp
Version: Oct 12 2015 03:31:21
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_SAT.rhp
Name: Adobe Illustrator Export
Version: Oct 12 2015 03:30:10
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_AI.rhp
Version: Oct 12 2015 03:34:06
File: /Applications/Rhinoceros.app/Contents/PlugIns/Alerter.rhp
Name: AutoCAD file export : export_ACAD
Version: Oct 12 2015 03:30:01
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_ACAD.rhp
Name: AutoCAD file import: import_ACAD
Version: Oct 12 2015 03:29:51
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_ACAD.rhp
Name: Comma Separated Value Export
Version: Oct 12 2015 03:28:57
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_CSV.rhp
Version: 5.1.161.0
File: /Applications/Rhinoceros.app/Contents/PlugIns/Commands.rhp
SDK Version: .NET -1.-1
Version: Oct 12 2015 03:34:10
File: /Applications/Rhinoceros.app/Contents/PlugIns/CreaseAngle.rhp
Version: Oct 12 2015 03:28:26
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_CD.rhp
Version: 5.1.161.0
File: /Applications/Rhinoceros.app/Contents/Resources/ManagedPlugIns/Export_DAE.rhp
Version: Oct 12 2015 03:30:29
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_FBX.rhp
Name: General Hydrostatics (GHS) Import
Version: 4.0.0.0
File: /Applications/Rhinoceros.app/Contents/PlugIns/Import_GHS.rhp
Version: Oct 12 2015 03:29:02
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_GTS.rhp
Name: GTS Triangle Import
Version: Oct 12 2015 03:28:55
File: /Applications/Rhinoceros.app/Contents/PlugIns/Import_GTS.rhp
Name: IGES Export Plug-in
Version: 5.1.161.0
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_IGES5.rhp
Name: IGES Import Plug-in
Version: Oct 12 2015 03:30:39
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_IGES.rhp
Version: Oct 12 2015 03:30:16
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_FBX.rhp
Version: Oct 12 2015 03:28:38
File: /Applications/Rhinoceros.app/Contents/PlugIns/Import_M.rhp
Version: 5.1.2015.131
File: /Applications/Rhinoceros.app/Contents/Resources/ManagedPlugIns/RhinoDLR_Python.rhp
Version: Oct 12 2015 03:30:55
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_LWO.rhp
Version: Oct 12 2015 03:30:50
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_LWO.rhp
Version: Oct 12 2015 03:27:05
File: /Applications/Rhinoceros.app/Contents/PlugIns/MeshTools.rhp
Name: MicroStation file import: import_DGN
Version: Oct 12 2015 03:27:23
File: /Applications/Rhinoceros.app/Contents/PlugIns/Import_DGN.rhp
Version: Oct 12 2015 03:28:22
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_UDO.rhp
Version: Oct 12 2015 03:34:44
File: /Applications/Rhinoceros.app/Contents/PlugIns/MPlane.rhp
Version: Oct 12 2015 03:27:12
File: /Applications/Rhinoceros.app/Contents/PlugIns/MRDKV5.rhp
Version: Oct 12 2015 03:31:06
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_OBJ.rhp
Version: Oct 12 2015 03:28:40
File: /Applications/Rhinoceros.app/Contents/PlugIns/Import_OFF.rhp
Version: Oct 12 2015 03:28:48
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_X_T.rhp
Version: Oct 12 2015 03:31:14
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_PDF.rhp
Name: PLY - Polygon File Format Export
Version: Oct 12 2015 03:29:21
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_PLY.rhp
Name: PLY - Polygon File Format Import
Version: Oct 12 2015 03:29:25
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_PLY.rhp
Version: Oct 12 2015 03:29:19
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_Points.rhp
Version: Oct 12 2015 03:31:17
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_Points.rhp
Version: Oct 12 2015 03:28:11
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_POV.rhp
Name: RAW Triangle Import
Version: Oct 12 2015 03:29:14
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_RAW.rhp
Name: Raw Triangles Export
Version: Oct 12 2015 03:29:12
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_RAW.rhp
Version: Oct 12 2015 03:28:15
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_RIB.rhp
Name: Rhino Bonus Tools
Version: Oct 12 2015 03:33:19
File: /Applications/Rhinoceros.app/Contents/PlugIns/RhinoBonusTools.rhp
Name: Rhino Labs Tools
Version: Oct 12 2015 03:33:32
File: /Applications/Rhinoceros.app/Contents/PlugIns/RhinoLabsTools.rhp
Version: 1.50, Oct 12 2015, 03:33:43
File: /Applications/Rhinoceros.app/Contents/PlugIns/RhinoRenderV5.rhp
Version: Oct 12 2015 03:33:07
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_SKP.rhp
Version: Oct 12 2015 03:33:00
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_SKP.rhp
Version: Oct 12 2015 03:29:08
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_SLC.rhp
Version: Oct 12 2015 03:29:05
File: /Applications/Rhinoceros.app/Contents/PlugIns/Import_SLC.rhp
Version: Oct 12 2015 03:27:41
File: /Applications/Rhinoceros.app/Contents/PlugIns/SolidTools.rhp
Version: Oct 12 2015 03:34:13
File: /Applications/Rhinoceros.app/Contents/PlugIns/Squish.rhp
Version: Oct 12 2015 03:31:47
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_STEP.rhp
Version: Oct 12 2015 03:31:26
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_STEP.rhp
Version: Oct 12 2015 03:32:00
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_STL.rhp
Version: Oct 12 2015 03:31:56
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_STL.rhp
Version: Oct 12 2015 03:29:37
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_VDA.rhp
Version: Oct 12 2015 03:29:31
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_VDA.rhp
Version: Oct 12 2015 03:32:54
File: /Applications/Rhinoceros.app/Contents/PlugIns/export_VRML.rhp
Version: Oct 12 2015 03:32:44
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_VRML.rhp
Version: Oct 12 2015 03:28:46
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_WAMIT.rhp
Version: Oct 12 2015 03:28:43
File: /Applications/Rhinoceros.app/Contents/PlugIns/Import_WAMIT.rhp
Name: WaveFront OBJ Import
Version: Oct 12 2015 03:30:59
File: /Applications/Rhinoceros.app/Contents/PlugIns/import_OBJ.rhp
Version: Oct 12 2015 03:28:35
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_X.rhp
Version: Oct 12 2015 03:28:28
File: /Applications/Rhinoceros.app/Contents/PlugIns/Import_X.rhp
Version: Oct 12 2015 03:28:18
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_X3D.rhp
Version: Oct 12 2015 03:28:32
File: /Applications/Rhinoceros.app/Contents/PlugIns/Export_XGL.rhp
Bitmap Table:
0 bitmaps, 24 bytes (offset 28255 to 28279)
Texture Mapping Table:
0 texture mappings, 24 bytes (offset 28279 to 28303)
Material Table:
0 materials, 24 bytes (offset 28303 to 28327)
Linetype Table:
linetype[0]: BORDER
linetype[1]: CENTER
linetype[2]: DASHDOT
linetype[3]: DASHED
linetype[4]: DIVIDE
linetype[5]: DOT
linetype[6]: HIDDEN
linetype[7]: PHANTOM
linetype[13]: PHANTOM2
14 linetypes, 2838 bytes (offset 28327 to 31165)
Layer Table:
layer[0]: Default
layer[1]: Temp
layer[2]: Frames
layer[3]: Top
layer[4]: Forward Network
layer[5]: Aft Sweep
layer[6]: Upper Forward Network
layer[7]: Upper Aft Sweep
layer[38]: New Paths 2
39 layers, 10084 bytes (offset 31165 to 41249)
Group Table:
0 groups, 24 bytes (offset 41249 to 41273)
Font Table:
font[0]: Default
font[1]: Times New Roman
2 fonts, 586 bytes (offset 41273 to 41859)
DimStyle Table:
dimstyle[0]: Standard
1 dimstyles with 1 plug-in data items, 741 bytes (offset 41859 to 42600)
Light Table:
0 lights, 24 bytes (offset 42600 to 42624)
HatchPattern Table:
0 hatchpatterns, 24 bytes (offset 42624 to 42648)
InstanceDefinition Table:
instance definition[0]: Body
instance definition[1]: Openings 0.04
instance definition[2]: Grill 0.01
instance definition[3]: Grill 0.02
instance definition[4]: Vents
instance definition[5]: 0 Pylon
instance definition[6]: Grills High Precision
7 instance definitions, 8464 bytes (offset 42648 to 51112)
Object Table:
object[0]:
object[1]:
object[2]:
object[3]:
object[4]:
object[5]:
object[6]:
object[7]:
object[658]:
659 objects, 581212910 bytes (offset 51112 to 581264022)
History Record Table:
0 history records, 24 bytes (offset 581264022 to 581264046)
Model User Data Table:
user table[0]: (1093 bytes)
Plug-in name: MRDKV5
Plug-in id: 16592D58-4A2F-401d-BF5E-3B87741C1B1B
user table[1]: (0 bytes)
Plug-in name: Rhino Bonus Tools
Plug-in id: 213A2661-A9EC-4ac4-867A-BC8CABE5AE29
user table[2]: (497 bytes)
Plug-in name: Rhino Render
Plug-in id: 5DC0192D-73DC-44f5-9141-8E72542E792D
3 user tables, 1893 bytes (offset 581264046 to 581265939)
Archive size = 581265959 bytes (end mark size = 581265959)
Why so many objects in your file?
Please describe your file.
Did you copy around a bunch of mesh trees or something?
Each object is averaging 861kb
I’d have to ask, what constitutes an object?
The end result is a solid with carved patterns in it.
This is what the file looks like with everything visible:
One thing that makes me wonder is that the isocurves of the components are not in the same orientation. Is there a command to reorient the isocruves that I might try?
Sorry, I can’t tell from the image.
Can you upload the file to us here using this tool?
http://www.rhino3d.com/upload
In the Comments, please include this URL:
http://discourse.mcneel.com/t/huge-file-growth/32190/10
I’ll have to try over night. Keeps cutting out on me during the upload.
If you have some other preference like Google Drive or DropBox, they work too.
It looked like it may have gone through.
