I’m using the ‘Tesseract OCR’ component in Grasshopper>Wizard. When I connect ‘TessData’ and it prompts ‘1. Please choose the correct folder where the data should exist’.
What I did was download the Zip files from GitHub, then unzip them, and then connect the paths to “Tesseract OCR”, and “Engine” select Default. The ZIP file’s content is shown in the screenshot below.
Do I need to do anything else? Such as licensing or other configurations? BTW, my Rhino version is R8, and the “Wizard” plugin was installed through PackageManager and is the latest version 1.1.7.
Following your instructions, it worked correctly in R8.
I also tested it in R7, and it worked successfully as well (It’s my fault for not testing the plugin directly in R7, cause I assumed it would work correctly in R8)
