clem1
(Clem)
1
Hi all,
I’m new to Rhino and I would like to run QuadRemesh from python instead of the UI.
I am struggling with running the following code:
import Rhino
from pprint import pprint
# Define parameters
parameters = {
'AdaptiveQuadCount': True,
'AdaptiveSize': 50.0,
'DetectHardEdges': True,
'GuideCurveInfluence': 0,
'PreserveMeshArrayEdgesMode': 0,
'SymmetryAxis': Rhino.Geometry.QuadRemeshSymmetryAxis.None,
'TargetQuadCount': 2000,
quad_mesh_parameters = Rhino.Geometry.QuadRemeshParameters()
for param_name, value in sorted(parameters.items()):
setattr(quad_mesh_parameters, param_name, value)
print("{}: {}".format(param_name, getattr(quad_mesh_parameters, param_name)))
print()
# Run QuadRemesh with parameters
rs.EnableRedraw(False)
for obj in Rhino.RhinoDoc.ActiveDoc.Objects:
if obj.IsNormal:
Rhino.RhinoDoc.ActiveDoc.Objects.Select(obj.Id, True)
print('Select Object ID', obj.Id)
print("Selected Status", obj.IsSelected(obj))
print('start remesh')
new_mesh = obj.Geometry.QuadRemesh(quad_mesh_parameters)
print('end remesh')
rs.EnableRedraw(True)
I see no change in the model after running this.
Besides, another weird prompt appears
Trav
(Travis Serio)
3
Hi Clem,
Here’s a python example you can start with at the link below.
clem1
(Clem)
4
That worked!
Thank you so much Travis.
The below code snippet applies QuadRemesh on all objects:
import Rhino
import scriptcontext
parameters = {
'SymmetryAxis': Rhino.Geometry.QuadRemeshSymmetryAxis.X | Rhino.Geometry.QuadRemeshSymmetryAxis.Y | Rhino.Geometry.QuadRemeshSymmetryAxis.Z,
def QuadRemesh(parameters):
go = Rhino.Input.Custom.GetObject()
go.GeometryFilter = Rhino.DocObjects.ObjectType.Mesh
go.GeometryAttributeFilter = Rhino.Input.Custom.GeometryAttributeFilter.ClosedCurve
go.SetCommandPrompt("Select Mesh to QuadRemesh")
go.Get()
if(go.CommandResult() != Rhino.Commands.Result.Success):
return go.CommandResult()
mesh = go.Object(0).Mesh()
qr_params = Rhino.Geometry.QuadRemeshParameters()
if parameters:
setattr(qr_params, param_name, value)
print("{}: {}".format(param_name, getattr(qr_params, param_name)))
print
remeshed = mesh.QuadRemesh(qr_params)
scriptcontext.doc.ActiveDoc.Objects.Add(remeshed)
scriptcontext.doc.ActiveDoc.Views.Redraw
return Rhino.Commands.Result.Success
if obj.IsNormal:
print 'Select Object ID', obj.Id
