How to use control key when get point
Hi;
Press the control key will lock the cursor when I use the customgetpoint function, I want to change the color of point when I press control key and get the point, it is way to solve it?
PS:
I push my core now, this core have somg problem, when I press the control key and pick point, the point have not delete, but it is not important, the important thing is affter this, the cursor have lock.
import Rhino
import scriptcontext as sc
import System.Drawing.Color
def GetPointAndDelete(points,ids):
  global poi
  while True:
    def GetPointDynamicDrawFunc( sender, args ):
      current_point = args.CurrentPoint
      for i in range(len(ids)):
        if current_point.DistanceTo(points[i])<1:
          poi=ids[i]
          args.Display.DrawLine(points[i], current_point, System.Drawing.Color.Red,3)
    def GetPointMouseEventArgs( sender, args ):
      if args.ControlKeyDown:
        sc.doc.Objects.Delete(poi)
    gp = Rhino.Input.Custom.GetPoint()
    gp.DynamicDraw += GetPointDynamicDrawFunc
    gp.MouseDown += GetPointMouseEventArgs
    gp.Get(True)
    if( gp.CommandResult() != Rhino.Commands.Result.Success ):
      return
    else:
      continue
pois = rs.GetObjects("get points")
points =[]
for i in range(len(pois)):
  point = rs.coerce3dpoint(pois[i])
  points.append(point)
GetPointAndDelete(points,pois)
@pythonuser,
i am not 100% sure i understand what you’re after but if you use CTRL in a GetPoint prompt it will lock the point picking in elevator mode and ask for a second point along the elevation line by default.
You can disable elevator mode by using:
gp.PermitElevator(0)
according to the help. To delete a point object with your script above using CTRL, i’ve changed it slightly. If the point is clicked without CTRL down, no delete happens.
import Rhino
  global poi
  while True:
          poi=ids[i]
          sender.Tag = poi
          pass
      else:
        sender.Tag = None
    gp.PermitElevatorMode(0)
    gp.Tag = None
    gp.Get(True)
      return
    else:
      if gp.Tag: rs.DeleteObject(gp.Tag)
      continue
points =[]
c.
Thonk you@clement.
Yes, it will lock, I means I do not want it lock, I will try your core affter het off work.
Think you @clement, I have try your core, that is it, it work good.
