The “offset” command can do the trick but it thickens improperly. It’s obvious in high amounts of thickness.
1.3dm (475.7 KB)
a.stp (245.3 KB)
Hello - you don’t say which direction or how far …
Outer direction and by 0.5
Hello - it looks correct to me so far…
no, The edges are not flat. I need them to be flat.
Hi, I added STEP version.
Hello - that would not be an offset, quite - I’d build the outside, then cap it and Shell
to get the inside.
