HI EVERYBODY
IM TRYING TO CREATE SOME RADIAL WAFFLE FABRICATION FILE IN GRASSHOPPER AND FOR THAT I NEED TO USE INTERSECTION COMPONENT BUT WHEN I USE 5 CURVE TO INTERSECT THE INPUT GEOMETRY IM GETTING 10 INTERSECTION CURVES !!
ANY IDEA TO SOLVE IT ?!
I ATTACH THE .GH FILE AND YOU CAN CHECK IT YOURSELF INTERSECTION PROBLEM.gh (10.6 KB)
you’re using brep|plane intersection which treats the planes as infinite constructs. you need to use brep|brep intersection instead, that will pay attention to the physical dimensions of the intersecting planes.
fundamental problems !
sry for such a simple questions
thank you
