Hi!
Is it possible to snap a control point from one curve to another curve? (End to Near)
So that when moving the first curve, the control point always would be glued to the second curve?
This is necessary for “RecordHistory”.
If make a surface on two rails with many curves and edit the basic curves.
If the point moves away from the curve, then the surface turns to crash
