Hey there, I am trying to attempt designing slab stairs that follow along a curve however when I used the ArrayCurve it caused to have gaps like this. The height of the slabs are 9" . ANy help is appreciated, I would love to learn how to fix this.
measure the distance between objects in the same orientation of the curve to know the spacing
Hey Diego, thanks for your response is there another method to design slab stairs following along a drive
Hello - assuming the curve is constant, then I think Diego’s way is pretty straightforward - if the curve varies, then of course it is more complicated - can you post your file?
another method could be using Shear with the option Rigid=yes , like this:
thank you diego for this solution
