In rhino we can set material to every face of the Brep easily,but how to do this by api?
I want to set material not a color
Oops, sorry. I don’t know how to do that
Hi @duzhengjie1,
Just set BrepFace.MaterialChannelIndex with the rendering material channel index of your choice.
var rc = RhinoGet.GetOneObject("Select Brep", false, ObjectType.Brep, out var objref);
if (rc != Result.Success || null == objref)
return rc;
if (!(objref.Object() is BrepObject brep_object))
return Result.Failure;
// Create red material
var red_material = new Material { DiffuseColor = Color.Red };
var red_material_index = doc.Materials.Add(red_material);
// Create blue material with red material on one channel
var blue_material = new Material { DiffuseColor = Color.Blue };
var red_channel_index = blue_material.MaterialChannelIndexFromId(doc.Materials[red_material_index].Id, true);
var blue_material_index = doc.Materials.Add(blue_material);
// Change object material to blue material
brep_object.Attributes.MaterialIndex = blue_material_index;
brep_object.Attributes.MaterialSource = ObjectMaterialSource.MaterialFromObject;
// Set every second face material to red material channel
var brep = brep_object.BrepGeometry;
for (var i = 0; i < brep.Faces.Count; i++)
if (i % 2 == 0)
brep.Faces[i].MaterialChannelIndex = red_channel_index;
else
brep.Faces[i].ClearMaterialChannelIndex();
// Commit changes and redraw
brep_object.CommitChanges();
doc.Views.Redraw();
return Result.Success;
– Dale
Ok,thanks very much!I have did it.
